Getting a dash fascia modified?
Can anyone suggest who to go to to have my dash fascia modified.
I want a single din radio and 3x 52mm gauges above it recessed into the dash slightly. At the moment I'm thinking boost, Oil Temperature and an analouge clock.
I was then planning to have the trim dipped in the brushed steel effect that it currently has to try and keep it looking OEM. Although my other half mentioned maybe having all the brushed steel trim done in a dark/black wood effect with matt silver gauges? She also suggested fitting a scangauge too but I'm mainly looking to monitor oil temps and the car only monitors cylinder head temperature.
But anyway... can anyone suggest somewhere I could get the dash fascia modified.
Bailes.
Bailes.
