efi conversion help fuel pump
Old Sep 15, 2014 | 02:41 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default efi conversion help fuel pump
Converted to efi had it running an booked in for set up,fuel pump was high pitched so changed it for a known working one,but has a weird farting noise when i prime it,i changed pump again for another,an i get same farting noise but wont start,any ideas as its due on the rollers friday,
Old Sep 15, 2014 | 02:50 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
do you have fuel at the rail and is fuel returning from the fuel pressure regulator
Old Sep 15, 2014 | 02:58 PM
TuRbO-CaB-LaD
Will check them both in a while cheers mate
Old Sep 15, 2014 | 03:46 PM
TuRbO-CaB-LaD
I have fuel at the rail,how do i check the regulator for pressure?
Old Sep 15, 2014 | 03:47 PM
TuRbO-CaB-LaD
Take top thin pipe off an get someone prime it?
Old Sep 15, 2014 | 03:59 PM
mk2grp1's Avatar
mk2grp1
when pressure is achieved at the rail it allows fuel into the engine whilst cranking, excess will return to the tank, yes the little return pipe comes off catch it in a jar crank very briefly,, then reconnect and check for spark with a plug on a lead near engine,
once the fuel vapours have cleared, has it ever run ?
Old Sep 15, 2014 | 04:41 PM
TuRbO-CaB-LaD
There is nothing coming out the top of the regulator,is this my problem?it was running after conversion but had high pitched fuel pump,so replaced it,i do have spark
Old Sep 15, 2014 | 05:00 PM
mk2grp1's Avatar
mk2grp1
on a cvh fuel rail fuel is fed into the screw fitting end of the rail
return is underneath the reg , the top pipe is only vacuum
Old Sep 15, 2014 | 05:14 PM
TuRbO-CaB-LaD
Ok so i need to pop bottom pipe off then,cheers will try it
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
kevin36
Sep 8, 2015 12:23 PM
bigryrs
Sep 7, 2015 06:45 PM
