Ap clutch finally fitted
Old Sep 10, 2014 | 06:48 PM
mintseries1's Avatar
mintseries1
Default Ap clutch finally fitted
Right after about 18months I've finally had my clutch done, as people advised on here I went for the organic cp2000-8 and also had the mk5 mod done aswel, now the biting point is literally on the floor, but my question is, how far can I turn the bolt to adjust the biting point before getting problems?
Old Sep 10, 2014 | 08:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The bolt raises the pedal, so you can adjust it a fair bit (pedal sky high) before it's too far... Just go a few turns at a time until you get it where you like it mate.
Old Sep 10, 2014 | 09:34 PM
mintseries1
The pedals near enough level with the brake pedal, I was under the impression turning the bolt clockwise it raises the biting point, or am I wrong??
Old Sep 10, 2014 | 09:42 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It adjusts the pedal height (Bolt acts against he quadrant pushing the pedal further away or pulling it closer), it does nothing to the clutch itself mate.
neil18
Mar 14, 2016 01:08 PM
Chas
Sep 21, 2015 08:57 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
