1.6 Zetec-Se Rebuild
Old Sep 10, 2014 | 01:57 PM
Straight_4_N/a's Avatar
Straight_4_N/a
Default 1.6 Zetec-Se Rebuild
What am I missing off this list for rebuild? It feels like I've forgotten something and its been over two years since I rebuilt an engine and I've never done a S/SE engine.
Top End Rebuild
Rocket Cover Bolts- £
Rocket Cover Gasket- £
Valve Stem Seals - £
Head Bolts - £
Head gasket - £
Inlet Manifold Gasket - £
Exhaust Gasket - £
Cam Belt Kit - £
Spark Plugs - £
Camshaft Sesnor - £
Water Temp Sesnor - £
Bottom End Rebuild
Piston Rings - £
Con Rod Bolts - £
Main Bearing set - £
Big End Bearing - £
Sump Gasket - £
Sump Bolts - £
Oil Pressure Sesnor - £
Crank Sesnor - £
Thomastat Bolts - £
Thomastat Housing -£
Thomastat - £
Water Pump - £
Flywheel Bolts - £
Oil Filter - £
Dip Stick tube O Ring - £
Crank Case Beather Gasket - £
Crack Case Beather Bolts - £
Thanks.
Old Sep 10, 2014 | 04:05 PM
mark826's Avatar
mark826
Thermostat seal? Cam seals? Crank and cam pulley bolts?
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
mondeomark
Sep 28, 2015 06:28 AM
