Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
ford fiesta mk6 eac failure
Old Sep 8, 2014 | 10:25 AM
sunhill's Avatar
sunhill
Default ford fiesta mk6 eac failure
Hi Guys,
I am a new ford owner,*
Have a 2003 ford fiesta, 1.6, 16v Duratec (Sigma, Zetec SE ? ) *petrol,*
Been having a trouble with the Car lately.
Initially, I had the famous Hunting problem...
Read a fair few forums, saying usually the MAP sensor is the problem. I have taken it out about twice now, and Given it a nice clean. Also checked the vacuum hose, it was all in good condition.
Changed the Air Filter.*
The car was good for a few days.
The problem has now returned.*
Have done a Diagnostic run using the OBD reader ( one off ebay) - I keep getting 3 errors usually -*P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
- P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
- P0113 Ford - Intake Air Temperature Sensor Circuit High Input
now also got a new code -*P2108 Throttle Actuator Control Module Performance.
Wondering if someone could give me a guidance, at what i should be doing next, ?
I have tried cleaning the connectors, lots of Contact cleaner sprayed. Still the same issues.*
I have bought a new MAP sensor , but not installed it as yet. in a hope maybe, it is just an electrical fault??*
tomiii
12
Aug 18, 2015 08:40 PM
Botts
Aug 13, 2015 04:16 PM
