engine oil temp 150 degrees ?????
Old Sep 7, 2014 | 04:07 PM
petemos's Avatar
petemos
Default engine oil temp 150 degrees ?????
Just pulled out a rally today as my engine oil temp went of the gauge above 150 degrees!! My turbo isn't water cooled and I use antilag which will heat up the oil.......surely I must have a duff sender or gauge?? The gauge and sender were bought together but it isn't a branded make??? I also have a 19 row oil cooler?
Old Sep 7, 2014 | 05:10 PM
RichieST's Avatar
RichieST
What was the oil pressure and water temps like?
Old Sep 7, 2014 | 05:16 PM
petemos's Avatar
petemos
Water temp was around 100 and at idle the oil pressure was 2 bar ish?? This was after an 8 mile stage. I'm using Mobil 1 15 50 motorsport oil
Old Sep 8, 2014 | 04:02 AM
slammedorion's Avatar
slammedorion
I'd be ringing Opie oils and chatting with them...
I was seeing 130 degs on the motorway, I rung them and was advised to try a different oil...
It run slightly cooler but I had piece of mind that once a oil cooler was fitted, my oil would do its job...
Old Sep 8, 2014 | 09:58 AM
tony66's Avatar
tony66
Default turbo
i"ve always thought that for heavy use[such as yours] a water cooled turbo core is far better
would be intresting to see the drop in temp with a quality water cooled item
those american type oil cooled only turbos are great for what they do best-1/4mile..
manuel boeckx
13
Oct 3, 2015 02:29 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
