Mounting floor mounted pedal boxes.
Wye Valley Hardcore
How has everyone else mounted theirs? The Tilton website says to use an M8 fastener and a large washer but surely the floor pan will flex on an Escort?
I was thinking about stitch welding two 6mm thick bars (similar to the files I've sat it on) to the floor and bolting the box to this, or is that a bit overkill.
Also, the pedals need to be vertical when depressed, so angled toward the driver when not pressed. Is that right?
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
You'll be surprised how much force you put through the pedal box
Mine is mounted on a false floor (approx 70mm high) and has similar bracing to MKs underneath. Held in place with high tensile socket cap bolts.
Wye Valley Hardcore
That looks good as well. I thought some "large washers" wouldn't do the job. Another bit of fab work to sort out! Good job I enjoy doing it!
Orion_Gav
Sep 29, 2015 04:50 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
