EFi turbo crossover touches bonnet :-(
Just fitted an EFi turbo engine in my cabby and the EFi cross over touches the under bonnet cover, anyone had this problem.
Am I right in thinking the XR3 cradle and RS turbo ones are the same???
Ginger
Ginger
So you have spaced your cradle?? Did you space the mounts too?? Otherwise your engine and box will be lay down to one side!!
Just put protective matting on the inside of your bonnet and use bonnet raisers. And also buy a set of vibratechnics are standard ford ones are shite!! Had to do that with my frst
Yer already got vibratechnic mounts on there, only lowered the gear box side (font and back) 5mm which wont hurt it, plus public roads aint level anyway
no need to do the other side. I had the car on level ground with the front slam panel almost spot on level and the gearbox end sit high than level anyway :-/
Ginger
Ginger
Matt Baxter
Sep 16, 2015 08:30 PM
marky_g
Aug 15, 2015 10:43 AM
