ford focus 2007 1.8 tdci HELP ME PLS
hi all ill start off by saying thanks for any reply as this is driving me mad
i have 1.8 tdci on an 08 plate with the euro 4 engine its the estate version
my symptoms are as follows
1200rpm judder
over 60mph steering wheel judders not shakes had tracking and balancing done i have just recently found out my disk are warped
i also can feel the engine threw the accelerator pedal when in low revs and the injectors rattle once over 2000rpm feeling goes
also when in traffic i can smell emissions coming in to the cab threw the window and vents not that strong
strong emissions smell out of exhaust
ok what i have done in the past 9 months of owning the car all done by warranty wise with a bit of a fight
i ave had a duel mass and clutch done small hose that runs from the turbo 4 injectors and a new high pressure pump swaf was found in my filter when they change the pump and injectors i also have a full server and my belts done.
now other than that iam getting 42-45mpg around town depending how i drive motorways -55-65mpg which is good i think.
anyway please if you can shed some light that would be great i have had 3 mechanics including a ford one look and they can not find the problems
1200rpm judder
