rs turbo id
Old Sep 2, 2014 | 09:44 PM
Connect's Avatar
Connect
Default rs turbo id
hi guys. ive just bought an mk4 rs turbo shell/project . mainly for spares tbh as the shell is quite badly rotten ,
The floor area where the chassis number would be is almost missing and there is no vin plate , no glass or any other details with the vehicle reg or anything obvious on it anywhere that i can see
is there any way or places i can check for any information that might give any hints or details of the identity .
any other vin or chassis numbers i could look for or anything like that
if i can get the confirm the identity and if it is a genuine rs i may repair it
thanks
Old Sep 2, 2014 | 10:28 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
if vin tags are off, its scrapped and the previous owner is covering himself by making the reg permanently gone , or the seller is keeping the "ringing kit"
along the sills there would be nutserts fixed to the shell for the bodykit side sills
and a horizontal line of say 2-3 mm holes about a foot apart above the nutserts,
for the sill skirts to prevent sagging, these were riveted on
turbo was fitted with 2 boxes engine ecu and fuel box behind the heater fan may be evidence of fixings there ,
, if its got these fixings , and the sill nutserts , its a turbo ,
you need the last 8-10 entries of the vin,
although dvla don`t assist without a reg number,
hpi may
Old Sep 2, 2014 | 10:31 PM
Connect's Avatar
Connect
where the chassis numbers where its very rotten so its not been cut out if that makes sense , as for the vin i have no idea ,
just wondered if there was any hidden chassis numbers or anything i could locate to help me
Old Sep 2, 2014 | 11:02 PM
mk2grp1's Avatar
mk2grp1
as said before silver vin plate been removed for a reason
ask the person you acquired it from,
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
