Mfi unusual idle
Old Sep 2, 2014 | 04:30 PM
S2 Cabby's Avatar
S2 Cabby
Default Mfi unusual idle
Hi all just a quick question, if an mfi turbo idles a little bit uneven what could be the cause? when you first start it it starts perfect every time and idles at about 1200 and then after a few mins it comes down to between 600-700 ish on idle, if I take it for a run with a bit of boost and then let it settle down it then idles back up at 1200 ish again? Puzzleing me I thought it might be the mfi unit it's self playing up but don't want to get a replacement without being sure. Thanks in advance
Old Sep 2, 2014 | 05:34 PM
Si74's Avatar
Si74
Should idle high initially from cold till the auxilliary air valve closes then settle to a steady idle (I think from distant memory about 3 minutes).
Can't help with your problem but I'd say 6/700 is too low an idle, should be nearer 900.
Old Sep 2, 2014 | 06:21 PM
RSmark84's Avatar
RSmark84
850 RPM should be the set idle, You can however change the idle speed(under the throttle body) this can sort the idle speed out. But really shouldn't be playing round with it unless you know what you are doing.
Get it set up, is the usual answer and I stand by that answer.
Old Sep 2, 2014 | 06:52 PM
S2 Cabby's Avatar
S2 Cabby
I only had it set up a few months ago but now I'm not so sure they done the best job
Old Sep 2, 2014 | 09:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Could be a few things, but air leaks are always the first thing to check with MFI.
Old Sep 2, 2014 | 09:57 PM
S2 Cabby's Avatar
S2 Cabby
I've had a good poke around and I can't find any and most of the vacum hoses have already been replaced?
Old Sep 3, 2014 | 06:51 PM
S2 Cabby's Avatar
S2 Cabby
A little bit of help from someone on here has said to check the cts so I'll give that a go and see if it's working properly
Old Sep 4, 2014 | 03:05 PM
S2 Cabby's Avatar
S2 Cabby
Right had a bit of a tinker around today and after about 50 test drives up and down the carriageway I'm hoping that I've got it but I'll have to wait until tomorrow when it's gone back to cold before I'm sure. Managed to get the idle to settle about 900rpm which I'm more than happy with so fingers crossed.
Old Sep 5, 2014 | 08:55 PM
essexRSTSouthend's Avatar
essexRSTSouthend
As above air leak or your mixture has already gone out of tune..
Chas
Oct 5, 2015 07:13 PM
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
stevierob
Sep 7, 2015 07:09 PM
