cossie 2wd timing belt tensioner query
Old Aug 30, 2014 | 08:43 PM
tony66's Avatar
tony66
Default cossie 2wd timing belt tensioner query
changed the timing belt on my 2wd saph today-put a new ina tensioner on it and a gates belt-the tensioner securing nut is a brass item with a rounded top-there is no washer...is this correct?
car is up and running now and fine-but its 2 decades scince i worked on anything yb-just wondering if there should be a washer...? i tightened it up to bit over 42nm
Old Aug 30, 2014 | 10:10 PM
jon@work's Avatar
jon@work
there shouldn't be a washer
make sure you tightened the tensioner the correct way (clockwise), or the belt can rub on the thermostat housing
Old Aug 30, 2014 | 10:24 PM
tony66's Avatar
tony66
Default tensioner
yes-i did it clockwise,thanks very much for reply
i am more used to dealing with jap stuff recently-this belt was 14 years old and still fine-but the tensioner was a bit worn,both would still have done a fair few miles more [was a gates fitted]
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
RsS2daz
Aug 14, 2015 05:26 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
lockie
Jul 31, 2015 10:03 PM
