3 door cosworth no spark !!!
Old Aug 29, 2014 | 05:35 PM
saph-mad's Avatar
saph-mad
Default 3 door cosworth no spark !!!
hi my cosworth has no power coming to the plug on the distributer or crank shaft sensor i have checked the wires coming out of the ecu and theres no power coming out of it to the two sensors i have changed the ecu and still have the same problem also fuel pump wont come on
Old Aug 31, 2014 | 12:03 PM
martysmartie's Avatar
martysmartie
They are both inductive pickups, thus they don't have a supply, so this is correct!
Look toward the CPS, as the pump won't prime until it receives input from it, this is assuming you have power to the ECU and relays?
Martin
Escortdriver1
Aug 19, 2015 09:02 PM
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
c14rks
Aug 11, 2015 05:17 PM
adriansaleem
Aug 1, 2015 09:28 PM
