help required engine wont rev past 1000RPM
Old Aug 26, 2014 | 08:02 AM
dean9595's Avatar
dean9595
Default help required engine wont rev past 1000RPM
ENGINE WAS RUNNING PERFECT FOR 3 MILES THEN
IT SUDDERNLY STARTED TO PLAY UP AND NOT REV PAST 1200RPM
HAD A LOOK NO PIPE OFF AND TICK OVER IS SPOT ON
ANY IDEAS
Old Aug 27, 2014 | 07:46 PM
Cossy Mike's Avatar
Cossy Mike
Throttle cable ?
Does the throttle body open?
Old Aug 27, 2014 | 08:04 PM
dean9595's Avatar
dean9595
Update is that picked car up from were I left it and drove home perfectly
But by the time I got home it started to play up again so it's temp related but what I'm under sure
Some say blue temp sensor on back of head to change first ?
Old Aug 28, 2014 | 05:30 AM
Cossy Mike's Avatar
Cossy Mike
Yeah back of the head above the brass dash temp sensor.
The ecu reads engine temps through the blue one. If its giving the ecu the wrong info it may be faulty.
Worth a try, but I don't think it will cure it. They either work or don't.
Check all of the jpt connectors on the engine sensors, you may have a broken wire
Old Aug 28, 2014 | 09:00 AM
timsrs's Avatar
timsrs
Check wires going to MAP sensor, will tickover (badly) but not rev....
Old Aug 28, 2014 | 06:14 PM
costina's Avatar
costina
Live long and prosper!!
Check the connectors to loom by the coil Dean, these play up for a past time and ive removed the plugs on many and soldered the wiring.
Paul
Old Aug 29, 2014 | 06:08 PM
tony66's Avatar
tony66
Default checks
also check map sensor pipework-and that you dont have a boost hose off...
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
borboyous
Aug 22, 2015 11:17 AM
IAN RS2k
Aug 18, 2015 07:51 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
