Total Compression Loss?
Old Aug 25, 2014 | 02:05 AM
Straight_4_N/a's Avatar
Straight_4_N/a
Angry Total Compression Loss?
What can cause total compression loss across all 4 cylinders without timing belt snapping and no nasty noises when it dies or trys to start?
Engine in question is a Zetec-S 1.7 VCT engine....
As I can't think of anything that would do it without the head or block them selfs blowing? and nor can anyone else explain it?
Old Aug 25, 2014 | 06:46 AM
RichieST's Avatar
RichieST
Snaped cam?
Old Aug 25, 2014 | 06:49 AM
Billy_RS's Avatar
Billy_RS
Rings? Spark plugs blown out?
Old Aug 25, 2014 | 09:23 AM
Unkle_bootz's Avatar
Unkle_bootz
First thing i would do is check the timing bud, pin in the crank and plate in cams, if timing is out then its possible the belt has jumped and you may have bent valves, if it was me though i would re-time the engine and stick a belt on it first and try it
Old Aug 25, 2014 | 12:04 PM
tony66's Avatar
tony66
Default engine
borescope it and have a look
Old Aug 25, 2014 | 12:31 PM
Straight_4_N/a
Rings to go on all four at the same time? Funny enough two of the spark plugs ceramic surround did blow the same time as engine cut out and two ht leads burnt out to.
Old Aug 25, 2014 | 12:32 PM
Straight_4_N/a
Originally Posted by RichieST
Snaped cam?
I was thinking that as I checked timing belt its self and it was fine.
Old Aug 25, 2014 | 02:32 PM
botters's Avatar
botters
competant bodger
ive seen these with melted exhaust valves before
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
Tank Mike
Sep 26, 2015 08:07 AM
