Cam belt timing marks and ignition timing
Old Aug 23, 2014 | 04:25 PM
slimwynn's Avatar
slimwynn
Default Cam belt timing marks and ignition timing
I've just been to check the timing and from what I can make out its set to four degrees is this correct as I thought if it had been set up it would be set to a higher number?
It's set between the 0 and 8 witch is 4 I was thinking??
Am I right that the marks are 0 4 8 12 16??
Old Aug 23, 2014 | 04:52 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
static timing is zero,
crank notch to the 0 , cam pulley pointer to the dot on head
with no1 piston at top of its stroke
a timing light is used for the higher number you speak of
12 degrees is the standard running advance,
this can be altered when an engine is upgraded/tuned
but can damage an engine if you don`t know enough to be playing around
Old Aug 23, 2014 | 05:31 PM
slimwynn's Avatar
slimwynn
Yeah I read that 12dbtc is standard that's why I was unsure why mine was set at 4dbtc I thought 8dbtc is the lowest you go when your tuning a car then keep advancing??.
Old Aug 23, 2014 | 05:51 PM
martysmartie's Avatar
martysmartie
You are talking about cam timing.
OP, the numbers on the cover are simply the number of degrees BTDC and is used for setting IGNITION timing.
Martin
Old Aug 23, 2014 | 06:13 PM
martysmartie
It isn't and you cannot possibly tell!
When the engine is running a strobe light is shone at those markings, the point of ignition marries with the notch in the crank pulley and then the STATIC ignition timing can be determined, which is 12 degrees.
In your case this is adjustable, on the Cosworth for example and all modern cars this is electronically set and is not adjustable.
It's a complex subject but basically the ECU will advance further from this dependant on engine speed, load and temperature etc.
The figure above is for a standard engine.
Martin
Old Aug 23, 2014 | 06:24 PM
GVK.'s Avatar
GVK.
On the RS Turbo the igntion is ECU controlled by the silver box, but the distributor still needs to be set-up so the base timing at idle is correct as even though the ECU controls the timing, if the base timing is out (retarded for example) the whole 'map' will be retarded, same goes for being over-advanced.
If you're setting it up, be careful you don't get any 'pinking' 'detonation'
Make yourself some 'det cans' and tune the car so no audible 'det'
Or even better get it set up by an expert on the dyno.
Also remembered the 12 degrees base timing should be with the vac hose from the ECU removed/blocked.
Old Aug 23, 2014 | 06:29 PM
GVK.'s Avatar
GVK.
As far as the cam timing goes when the cam belt pulley is showing the arrow lining up with the dot on the head at TDC the crank pulley should be on 0 (TDC) If you have the bottom pulley off the woodruff key on the crank should be at 12 o clock.
Old Aug 24, 2014 | 02:03 PM
martysmartie
You also need to consider the fuel you are using...
Martin
Old Aug 24, 2014 | 08:13 PM
slimwynn's Avatar
slimwynn
yeah I'm after a det monitor as I can't use cans on a track with wearing a helmet.
yes I checked the timing when the vac hose was blocked.
I have a wideband a/r gauge to keep an eye on fuelling.
I know taking it to a tuners would be best its just I'm keen on learning how to tune the rs mfi and in the near future I'm planing on going efi ofam.
I'm using 99ron fuel.
Old Aug 24, 2014 | 10:23 PM
martysmartie
How do you know what it is?
That figure tells you nothing, as it's for a standard engine, I would assume yours is modified?
Martin
Old Aug 28, 2014 | 08:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
So you are saying your idle/static ignition timing is 4 deg BTDC with the vacuum hose disconnected and blocked?
If so then yes that is unusually retarded... it may be there for a reason (det at full load WOT if any further advanced?) or you may have a faulty, ECU, ACT sensor, dizzy, etc..
Old Aug 28, 2014 | 10:48 PM
slimwynn's Avatar
slimwynn
yes m8 it's set at four with the hose off and blocked.
I take its four its set between 8 and 0
well i'm in the process of making some det cans so i can keep an ear on whats happening in the engine.
why when tuning do you keep advancing the timing whats it doing when you do??
cheers
Old Aug 28, 2014 | 11:59 PM
martysmartie
As above, I think his confused and is referring to cam timing instead, OP needs to describe what he done when he took that picture.
cheers[/QUOTE]
Advancing, like the name suggests means the point of ignition will occur earlier, relative to the pistons position, i.e. 12 degrees BTDC.
It's a complex subject, but basically the mixture needs time to burn to be most efficient, depending on the setup, advancing may give gains when done correctly, done incorrectly it will run worse and cause damage!
Martin
Old Aug 29, 2014 | 10:59 AM
slimwynn's Avatar
slimwynn
I'm only using the picture to show the markings on the casing as when I use a timing strobe the mark on the pulley is sitting between 8 and 0 when the engine is running.
Old Aug 29, 2014 | 12:06 PM
martysmartie
Right now we know that, that makes sense!
However, that is massively retarded, but it may not be depending on your setup, as said.
Martin
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
taylora1409
Aug 12, 2015 12:06 PM
