93 mk3 Fiesta Sleeper
Old Aug 17, 2014 | 10:54 PM
blt-nt-bght's Avatar
blt-nt-bght
Default 93 mk3 Fiesta Sleeper
Hi all!!
Im starting this thread mainly for ideas.
Im 18 and I want to make my lil fezza into a car I can use on the track because I have a Morris Minor 1000 as my daily so I need a track day car that I can go fast in so I can let my want to go fast out on the track instead of on the road!
Im going to do minimal body modifications because I like the idea of a sleeper but I wanna know what you guys think I should have lying under the bonnet?
Thanks!
Jack.
Old Aug 18, 2014 | 01:50 PM
sridgett's Avatar
sridgett
The only way is dagenham
Hi there mate and welcome to PF. Just drop a xr2i lump in.
Old Aug 18, 2014 | 03:38 PM
gjh's Avatar
gjh
A zetec engine will go in without much fuss, plenty of people on here have done it. That would make a good project.
Old Aug 18, 2014 | 04:21 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Don't bother with the 2i lump, they're nothing to shout about.
A simple and reasonably cheap but effective swap would be a 2.0 Zetec on a set of bike throttle bodies, K1/2 ones off a GSXR 1000 are ideal as they can be split so you can space them to suit. Then whatever ECU is recommended by your mapper, unless you're doing it yourself of course.
A friend has the exact same setup in a KA, it ran 160bhp on standard internals with ARP rod bolts, absolutely nothing inside bar a cage and a seat, with 300mm Mondeo brakes and slicks it's comical to drive.
Old Aug 20, 2014 | 11:10 AM
blt-nt-bght
Cheers everyone for the feedback, I was thinking 2.0 zetec on carbs but didn't know whether to go bike carbs or twin webers ect. All I really want is a cheap conversion for a bit more power because I just want to get used to the track in something then possibly upgrade to something bigger soon like a saloon. Plus I don't have a lot of money atm to plunge right into the fiesta because I'm restoring my morris minor too :/
Old Aug 21, 2014 | 06:11 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Bike carbs are a simple and effective route to take, gsxr thousand carbs work well with a Bogg Brothers manifold. You can run Fords EDIS 4 alongside a mappable ecu like Megajolt.
Old Aug 21, 2014 | 09:24 AM
Brendan's Avatar
Brendan
struggling with reality
why not go with old school turbo'd cvh? or nitrous? Both are tried and tested and give good results!
good luck!
Old Sep 17, 2014 | 03:31 PM
blt-nt-bght
Sorry I haven't replied!! All great ideas and I wish I could do them all really! But I've been given a ford puma so I think I'm gunna use the engine from that I know it's not a straight fit as it would be in a mk4/5 but I think it would be a bit different seeing a mk3 with a puma swap. I was just wondering if people knew how I'd go about it in terms of fuel pumps? Could I use the puma ecu for now to get it running? Cut puma and reweld the engine mounts in the fez?
Thanks,
Jack.
Old Sep 17, 2014 | 04:25 PM
zippyobrien's Avatar
zippyobrien
Just use the puma. Infanatly more capable to start with.
Old Sep 17, 2014 | 04:44 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
+1 on this, 1700 Pumas are incredibly capable out the box. I had one stripped out on coilovers with a lonely bucket seat seat and it was comical.
Old Sep 17, 2014 | 08:50 PM
blt-nt-bght
Cheers for responding! Unfortunately body work isn't too good and the fuel pump is gone, plus I fancy I little project to keep me going mechanically.
Old Sep 19, 2014 | 09:58 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
It'd be a good little project, not too difficult either if you can fab your own mounts.
I can vouch for the handling of a mk3 Fiesta, but 1700 SE lumps are cracking engines and are very light.
Old Sep 21, 2014 | 04:11 PM
blt-nt-bght
Yeah can do my own mounts so all good there! Does anyone one know how to go about fuel pumps and other stuff like that? Going from a carb engine so not to sure what to do there. Can anyone help me here?
Cheers,
Jack.
Old Sep 23, 2014 | 10:08 AM
blt-nt-bght
Hi again!
Does anyone know if the whole fuel tank just swaps over with the fuel pump sender unit? Or would running the 1700 se on carbs be a good/different idea and still you the original mechanical pump?
Cheers!
Old Sep 29, 2014 | 02:01 PM
blt-nt-bght
Hi, ive got the information for the fuel and all that sorted out now, i have got a new question though; does the rear beam from the puma bolt straight onto the fiesta along with the suspension too?
thanks,
Jack.
Old Oct 25, 2014 | 08:26 PM
blt-nt-bght
Hi all!
been to the scrapper today for a look around and an escort gti caught my eye! so I was woundering, what parts can I gut from it to fit little fezza?
cheers guys.
Old Oct 26, 2014 | 11:46 AM
Smidydevil's Avatar
Smidydevil
If the puma rear beam
Has the eye type mounted rear suspension and not the fork type then yes you can swap straight over to the fezza this will give you larger rear drums whilst increasing rear ended grip massively..
What engine route are you going for now ? Zetec or sigma engine? escort gti? No parts that I can think of would benefit you if not using the zetec engine, possibly the brakes but I would be going st170 route with 300mm's I have these brakes on a mk3.5 and they're monsters
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
