removeing underseal
Old Aug 15, 2014 | 04:51 PM
mpilk's Avatar
mpilk
Default removeing underseal
ive striped my car down to start to repare the body work whats the best way to remove the underseal is it hotair gun then wirebrush or is there something i can put on it to soften it up first
Old Aug 15, 2014 | 09:01 PM
tony66's Avatar
tony66
Default soften
petrol softens it-but no matter what you use its very time consuming
Old Aug 16, 2014 | 05:44 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
I did mine with a hot air gun, then cleaned up with panel wipe!
Old Aug 17, 2014 | 01:11 PM
Harryh24's Avatar
Harryh24
mine didn't even budge with hot air gun or even blow lamp! I had to wire wheel on grinders drills whatever I could think of! takes ages! but well worth it!
Old Aug 17, 2014 | 01:46 PM
mpilk's Avatar
mpilk
had a go today with hot air gun once i got the the top layer soft it started to come of then it was wire brush on grinder did a couple of hours then gave up, thinking about getting it blasted of just in wheel arches and the underside going to look into that i dont wont the panels damaging
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
