standard cam with hydraulic lifters
Old Aug 11, 2014 | 09:18 PM
tlr_rst's Avatar
tlr_rst
Default standard cam with hydraulic lifters
right this is a refresh of a previous post with new thoughts
spoke to steve at Jamsport, he is able to get me a standard solid cam made by Newman and hydraulic lifters for my spec of car. Which is totally standard, so will be like factory, apparently
Anyone done this before? what Newman cam is it? Does it last??
all help greatly appreciated
Old Aug 12, 2014 | 05:49 AM
mentalasanything's Avatar
mentalasanything
Newman cams will be the best of what you can get. They'll just make a copy of the original, so standard profiles. It may not even have a part number.
I've driven past Newman cams on the A21 numerous times. It just looks like a small machine shop, but they are highly regarded for what they do.
Don't expect it to be cheap though.
Lee
Old Aug 12, 2014 | 08:49 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
why bother with high costs of a decent cam without having any advantages over what you have. Also newman, kent, piper etc don't make hydraulic lifters. Where do you think they come from?
Even an off the shelf mild road cam would be fine if you wanted to stick around standard power. By the time you dialled it in and set the cam properly with std parts you probly wouldn't see much gain anyway maybe a few bhp but still drive the same.
Why not get a slightly larger intercooler paint it black so you don't notice it. Fit a chip if it doesn't have one and then the mild cam will make it a bit more lively and still look stock under the bonnet.
Old Aug 12, 2014 | 04:50 PM
tlr_rst's Avatar
tlr_rst
hello fella
what mild road cam would you suggest then if its existing rather than having one made up?
just at revs 4k and above its a bit rattly like nails, maybe its like that normally not sure, also gears in first and second when revving a little bit rattly nothing major
Old Aug 13, 2014 | 06:02 AM
Versus_Creations
Ask me a question!
Its an old cvh. Unless you change the liftrs it will be loud.
Any cam will do what you want mate. Cvh34 I dont like these cams but for your spec its prob best choice.
Old Aug 14, 2014 | 12:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What's important to mention here is that the engine has done 177k miles and is untouched, I wouldn't recommend upping the power.... I would recommend a full rebuild if money allows, if not then just a replacement cam, Newman is the best of what's available IME, you could risk a cheap Motor factors replacement but if it falls apart and then writes off what's left of your bottom end it's money wasted, albeit not much! lol
cos elle
Sep 25, 2015 09:52 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
