Pictures, video & Photoshop ForumIf you want to show off your photoshop skills, share pics and videos of your car or other cars you've found, here's the place to go.
yea is garys old motor
T3 is still going strong as well
you don't happen to know if the engine is running standard compression do ya?
and if the bottom end is standard as well?
many thanks
Daz
many thanks
Daz
You'd have to speak to Gary about that mate as I am not sure about the bottom end. He is now MK11 Garry on here now so send him a pm.
yea would be twins if i had the voodoos on it still
what sorta power you running with yours at the mo?
Made 251 bhp / 263 lb ft torque, but have put a T34 on with the cossie .63 housing and lowered the boost a few psi. So prob about the same at the mo. Gonna go steel bottom end next year and then raise the boost as much as possible as it is only running a bar at the moment.
nope, only problem is full lock is a bit less than when I had a 15's on
you got problems with urs then?
used to catch on full lock at speed and rear arch but that was just the
mudflap mount, its getting resprayed at the moment so will be getting more trimmed or arches then
