DTA S40 and Launch control Q
Old Jul 31, 2014 | 09:30 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default DTA S40 and Launch control Q
Right the DTA S40 has Launch control but no Anti lag
does this mean it wont spool up when idle and limit set to 4k example like? eg like Stu @MSD does on L8
i know it wont have Anti lang when lifting off throttle during driving but want sure if that is anti lag aswell when your spooling up from standstill?
Old Jul 31, 2014 | 09:38 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Essentially a soft cut rev limmit, thus building boost "in 1st gear" (or with handbrake on, depending on switch fittment position)
Old Jul 31, 2014 | 09:51 PM
Roosie's Avatar
Roosie
so it will show positive boost at idle?
Old Jul 31, 2014 | 11:00 PM
Sonic Boom's Avatar
Sonic Boom
The launch control on my EMU, adds abit more fuel, cuts the spark to limit revs, retards the ignition and builts up the boost while stationary.
You can adjust the fuel, rev limit and ignition retard, more retard equals more boost.
Rich
Old Aug 1, 2014 | 03:10 PM
stevieturbo's Avatar
stevieturbo
C**t
Newer versions of the software do have a timing retard feature that should assist building boost on the line. "Retard before cut when car stopped"
But depending on turbo size, and desired launch rpm, it may build some boost anyway without the timing retard.
It's a fairly basic setup either way
Old Aug 1, 2014 | 03:28 PM
Roosie's Avatar
Roosie
Anyone got any base maps for a DTA ?
Old Aug 1, 2014 | 03:44 PM
stevieturbo
C**t
There are multiple maps included with the DTA software.
Whether they are a suitable "base" for your setup is another matter. It isnt hard to throw together something for most engines though.
Old Aug 1, 2014 | 04:13 PM
davidfox280585's Avatar
davidfox280585
I'm running Dta s40 on my zetec turbo and very interested in this feature, it will be getting installed aswell as the traction control this winter aswell as the frs gearbox,a few more details on the launch would be great as I'm hoping it's going to give a few pops and bangs
Old Aug 1, 2014 | 04:24 PM
stevieturbo
C**t
http://www.dtafast.co.uk/Downloads/M...s%20Manual.pdf
Traction control will be very limited on the S40 ( TBH not even sure it offers it ?...just checked manual, nope.)
Launch details P50 onwards.
Old Aug 1, 2014 | 04:31 PM
davidfox280585
Stevie yes your right just looked, thought it supported it will just have to work that throttle a little harder
Old Aug 1, 2014 | 06:38 PM
Roosie's Avatar
Roosie
http://www.dtafast.co.uk/compare_ECUs.htm
here it says it has launch control?
Old Aug 1, 2014 | 07:46 PM
stevieturbo
C**t
Launch control is not traction control.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
Thanasis
Sep 7, 2015 07:33 PM
