Stack st700 issue
Old Jul 26, 2014 | 05:40 PM
jamie956's Avatar
jamie956
Default Stack st700 issue
Need help with my stack tac/display I have it set to display oil press and temp but I can not get the pressure to read correctly, what ever I do it just reads 99.9 bar or 999 psi tried every setting swapping the wires on the sensor but just get the same, every once in a while it seams to rest it self starts at zero and then counts back up to 99.
Old Jul 26, 2014 | 05:43 PM
Paul_RS's Avatar
Paul_RS
Try grounding the body of the sensor, if you are using some form of take off plate that's not grounded to the engine the gauges won't read.
Old Jul 26, 2014 | 06:11 PM
jamie956's Avatar
jamie956
The sensor is fitted into a block adaptor where the normal oil pressure switch would be, it was fitted with a bit of hermetite round it so I guess it could be insulating it.
Mark_
14
Jan 16, 2016 05:27 PM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Sep 29, 2015 09:06 AM
SMILER258
Sep 28, 2015 09:04 AM
pabloXR
Sep 21, 2015 12:42 PM
