Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
water dripping
Old Jul 26, 2014 | 10:26 AM
andrewblueboy's Avatar
andrewblueboy
Default water dripping
hi all
i have a drip from below the two pipes wich go thro the bulkhead for the heating.well just below these 2 pipes there one pipe which comes out from the bulkhead and is only a couple of inches long and this is were the drip comes from. so does anyone have any ideas whats this pipe could be .
car is a 1.6 with aircon if it makes a difference,and at the momment with this weather its used all the time. thanks
Old Jul 26, 2014 | 10:41 AM
uruk hai's Avatar
uruk hai
Is the water level dropping ?
Could be a few things, catch the drips if you can and see if the water contains anti freeze. If so I'd say the leak is from the pipes feeding the matrix.
Old Jul 26, 2014 | 10:49 AM
andrewblueboy
when i spotted the drip i caught some in a tub and it was clear. top up bottle is full with orange anti freeze. is there anything i could use to test for anti freeze in water
thanks for quick reply
Old Jul 26, 2014 | 10:50 AM
RichieST's Avatar
RichieST
It's the condenser drain for the air con. Totally normal, nothing to worry about.
Old Jul 26, 2014 | 10:57 AM
andrewblueboy
ah thanks richiest for that quick reply. i was starting to panck, cheers
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
