Garrett turbo identification
Old Jul 23, 2014 | 09:46 PM
ekjim's Avatar
ekjim
Default Garrett turbo identification
Im looking to see if anyone knows what turbo this is garrett number 700177-5014.
Old Jul 24, 2014 | 02:10 PM
Fast Guy's Avatar
Fast Guy
Google is brilliant.
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
Old Nov 16, 2014 | 06:56 PM
ekjim's Avatar
ekjim
Does anyone know how this would compare to a cosworth t4 turbo ?
Old Nov 16, 2014 | 10:22 PM
scoooby slayer's Avatar
scoooby slayer
in theory it should spool better and make more power, atp say its rated to 600 hp but it will depend on what turbine housing you use.
ive owned 2 t4 yb cars and they were lag monsters, the bb core and better wheel design of the gt30 should give better response.
Old Nov 19, 2014 | 09:38 PM
ekjim's Avatar
ekjim
It says on the cold side ar 70 not sure what to ask guy what hot side as he says theres no cast numbers on hot side.How do you think this would be on a non vvt sr20 Anglia, its currently got a t34 with 63 exhaust side want to do a bit of drag racing .
Old Nov 19, 2014 | 09:48 PM
scoooby slayer
the ar number should be stamped in the turbine footplate inlet my gt40 was, is it t3 or t4 ?
identification on outside gt40 1.06 ar housing
and identification inside the flange where the turbo bolts to the manifold 0.85 ar housing
Old Nov 20, 2014 | 09:21 PM
ekjim's Avatar
ekjim
Thanks now that I have that information I should be able to find out more .
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
