petrol keeps clicking at the pump
Old Jul 22, 2014 | 09:22 PM
tlr_rst's Avatar
tlr_rst
Default petrol keeps clicking at the pump
everytime i fill up it takes like 15 minutes to do a full tank, i feel a right standing there bent over filling the car up for so long.
basically it'll fill for a while then "click" wait for the fuel to go down, fill and then click...this will go on for ages, holding the handle on the nozzle slightly so it fills up soooo slow works but takes ages.
i guess theres a breather problem somewhere, theres a "thing" attached to the down pipe that has 2 small breather pipes running off but need some thoughts first as it seems fine
what would you suggest???
Old Jul 22, 2014 | 10:21 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Sounds like a blocked breather on the tank to me
Old Jul 22, 2014 | 10:24 PM
beaver rs 88
in the garage
I would suggest taking the two little pipes off at the filler neck and see if it makes it any better to fill up before dropping the tank. Be careful though as they tend to be very brittle these days.
Old Jul 23, 2014 | 05:44 AM
B19 JUB's Avatar
B19 JUB
I get the same problem with my orion.after about £2 its at the top of the neck.i have to very very slowly pull the pump trigger and wait
Old Jul 23, 2014 | 06:23 AM
tlr_rst's Avatar
tlr_rst
take the 2 pipes off at the filler neck
that sounds a good idea to me and then can see if it fills ok
thanks for the help
Old Jul 23, 2014 | 08:21 AM
r06ert's Avatar
r06ert
had this probelm with he BMW for a while, was told to hold the handle up side down when filling, worked for me
Old Jul 23, 2014 | 08:52 AM
haz87's Avatar
haz87
Have always had this issue (all breathers/pipes clear - even removed the main filler neck to check for obstruction). Has been the same on both mk4's ive owned, i just live with it. Tho 15mins seems a tad excessive, im usually standing there for 5 (had the car too long to still feel like a moron nowadays )
Old Jul 23, 2014 | 08:53 PM
studabear's Avatar
studabear
Is it also not down to the fact that these old things were designed for 4star fuel and the pump nozzle angle/shape was different to the unleaded design.
Old Jul 24, 2014 | 09:14 AM
mentalasanything's Avatar
mentalasanything
I agree with studabear. I have this same issue with the cabby. If you pull the nozzle out by about an inch so the handle drops and changes the angle it works fine.
Lee
Old Jul 24, 2014 | 08:39 PM
tlr_rst's Avatar
tlr_rst
well at least i know i might not be the only one with this problem, cheers guys
Old Jul 24, 2014 | 11:01 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Nope defo not the only one . It's happened me before
I over filled mine once because of it ......... Probably left 10ltrs on the forecourt
Old Jul 25, 2014 | 06:34 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Lee
Yep, same here
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
20/20 vision
Sep 29, 2015 11:27 AM
