Are these the correct ones?
Old Jul 22, 2014 | 08:56 PM
Si74's Avatar
Si74
Default Are these the correct ones?
Need a new set of braided flex hoses for the rear.
Like the look of these on ebay but the connectors are different from my old ones. Mines have the connector on the left of the photo at both ends. They were changed years ago from standard so never seen the spring clips supplied with these, do they go where the rigid pipes meet the flexis on the chassis rail?
Sorry thought I could just post the photo, no go so here's the link:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=371105705655
Old Jul 23, 2014 | 10:30 PM
Si74's Avatar
Si74
No body? It's 14 years since I drove it and probably 19 since I rebuilt the front end so I'm a bit rusty, as are my tools
Old Jul 24, 2014 | 02:13 PM
millybuzzin's Avatar
millybuzzin
The clips are for connecting to the chassis rails on the rear.sorry not sure about the connections I will have a look at mine)
Old Jul 24, 2014 | 04:26 PM
Si74's Avatar
Si74
Thanks for that, don't want to buy them and find out they are no use.
Not really up on brake pipe fittings and already went through 50ft of pipe trying to make new brakelines. Mine are better than the crappy attempt the garage did but I want them spot on.
Old Jul 24, 2014 | 08:19 PM
55rsturbo's Avatar
55rsturbo
Default braided hoses
hi mate bought some of these for the front of my s2, and they made a longer set for the back 600mm long the ends are duel purpose i have not bled them yet but appear to be ok. cheers frankie
Old Jul 29, 2014 | 04:48 PM
Si74's Avatar
Si74
Thanks Frankie, I'll take a chance on them, they look nice.
Old Jul 30, 2014 | 07:40 PM
55rsturbo's Avatar
55rsturbo
they work ok bled out fine no leaks cheers
Old Jul 30, 2014 | 09:54 PM
Si74's Avatar
Si74
Thanks for that as I took a chance and ordered them yesterday. Just need the clips that hold them to the dampers now.
Old Aug 5, 2014 | 10:01 PM
Si74's Avatar
Si74
Bought these, nice enough made but my car must be an alien!
The end that goes through the bracket on the rear chassis leg wouldn't fit.
The hole thru it has a flat side, took the wee grinder and made them fit but was a lot happier when both ends were the same and I could get a nut and washer holding it to this bracket.
Getting the spring clip affairs on over all the paint and gravitex is going to be a pain and not convinced it's nearly as strong as the old set up.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
Fiddy
21
Sep 29, 2015 06:10 PM
RSmark84
Sep 13, 2015 01:29 PM
