Cosworth 2wd head problem
Old Jul 21, 2014 | 09:07 PM
COLEYST200's Avatar
COLEYST200
Default Cosworth 2wd head problem
Hi lads I'm having a problem with the head on my Cosworth focus can any one shed any light on it . Two weeks back it suddenly used some water a bit od as it's very good on that side any way on a small drive after putting some water in the temp on the dash went up into the red and the blower went cold so I pulled over and put some more water in when it was cold a nuth to get the cap off . Well I fort to my self check the oil filler cap and the oil was starting to chang to a cream so I just fort ok the head gaslit is on it's was out so off with the head and to be onist I could not see much rong with it apart from number 3 piston was very clean witch made me think that's wair the gaskit must of gone any way a new head gaskit was fitted and the car was put back togever the old oil removed and as there was a lot of water it the oil I just put some old oil back in the motor to run for ten min then drop it and put some new stuff in . Well the time come to do a road test and to be onist it wa fealing a bit lumpy on one cilinder wall I was only out 5 min and the temp went up again so I got it back home and it had used a good amout of water and the oil was like cream again . It's punting to me that the head is cracked on the inlet side but it would be good to hear your replys to this problem . The head is coming back off tomorrow night and going in to be looked at
Old Jul 21, 2014 | 09:14 PM
Southeastsaph's Avatar
Southeastsaph
Did you get the cylinder head pressure tested or surfaced??
Old Jul 21, 2014 | 09:20 PM
COLEYST200's Avatar
COLEYST200
I will be onist mate I did not :-(
I no I should of but it's more £ and as I'm going throw a devours at the mo I'm just trying to keep things going on the cheap but this time it's bit me in the ass .
Old Jul 22, 2014 | 12:17 AM
richard youll's Avatar
richard youll
Head off again, pressure test and skim if needed, I've had 2 customers in the last week both one 2wd and one 4wd both head cracked to fook!
Old Jul 22, 2014 | 06:12 AM
COLEYST200's Avatar
COLEYST200
I'm really hoping it's not cracked but deep down I no it's going to be :-(
Old Jul 22, 2014 | 03:09 PM
costina's Avatar
costina
Live long and prosper!!
Could be the water to oil cooler modine......
Disconnect water pipes link together and try again.
Old Jul 22, 2014 | 03:18 PM
BigErn's Avatar
BigErn
Could be the block.... I had a 205 block crack a cylinder liner. Got a new liner fitted and engine went again after 1500 mile so so I got rid of the car
Old Jul 23, 2014 | 09:30 PM
richard youll
It can't be the modine because it has a misfire and a piston crown has been steam cleaned , if it was the modine you would solely have oil/water mix, I must say I had a 205 with a pin hole in a bore that when the piston came up put water in the sump and when the piston was down put the water in the bore so you may not have a head issue but a block issue, best bet is pressure test the built engine and drop a bore scope down before you strip it
Old Jul 23, 2014 | 09:38 PM
COLEYST200's Avatar
COLEYST200
Thanks mate I would of looked at the but the head is now off the car and in at a place I use to do my heads in the past my mate Rex tuck it in for me and I should by midday Friday no if it's any good or if it's for the bin . Rex said that the chap was very optimistic when he sore it Ashe said it didnot look like it was sealing 100% on number 3 and that pitting in the water ways was not helping so I'm keeping them Crost at the mo
Old Jul 25, 2014 | 10:59 PM
COLEYST200's Avatar
COLEYST200
Right thanks for your replys lads I'v started to take the motor out of the car as the head come back today with a clean bill of health so we had a good look at number 3 in the block and gess wot the block is cracked . It's a 205 block on 1st over size but luck would have it I'v got a spare 205 in 1st over size so tonight that block has been cleaned up and I will push on tomorrow with getting the old Motor out and build up a new motor as I really won't to get this car to ford fair under its own steam thanks again for your help lads
Old Jul 27, 2014 | 10:06 AM
costina's Avatar
costina
Good point well made it will teach me to read the post correctly
At least you have found this problem and have a spare block.
Old Jul 27, 2014 | 04:43 PM
Non custom's Avatar
Non custom
Least ya got down to bottom of problem
turbotrev
Aug 22, 2015 11:41 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
