ecu chip
Old Jul 21, 2014 | 02:46 PM
gi2490's Avatar
gi2490
Default ecu chip
i am running standard yellow injectors, 2 bar MAP and garrett AR48 turbo.
i am looking for a power chip for this set up any advice please.
Old Jul 21, 2014 | 08:18 PM
martysmartie's Avatar
martysmartie
After confirming the engine is in good health, you need a stage 1 chip, which can be purchased from MSD etc.
This will allow a higher boost pressure, and around 270-280 HP.
Martin
Old Jul 21, 2014 | 08:34 PM
opposite lock's Avatar
opposite lock
As above and they can custom write you a chip if needed.
http://shop.motorsport-developments....hips-169-c.asp
Old Jul 24, 2014 | 02:30 PM
gi2490's Avatar
gi2490
does any one know if MSD stage 1 chips are plug and play.
sent stu a PM no reply
Old Jul 24, 2014 | 02:42 PM
opposite lock
No there will be certain adjustments to make and making sure everything works and is set correctly.They will supply the info you need.
New actuator will probably be needed too.
Just make sure everything is healthy and performing well before you do it.
Old Jul 24, 2014 | 03:30 PM
gi2490's Avatar
gi2490
engine has just had major overhaul.
would i need a dyno to set the chip.
Old Jul 24, 2014 | 04:56 PM
tony66's Avatar
tony66
Default check
afrs and det need checking under load
this can be done on the dyno or road
as said above-make sure all is good-sensors/leads/fuel supply/clutch/cooling/belts/ plenty fuel of the type you use..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
RSmark84
Sep 13, 2015 01:29 PM
