Jerking around problem
Old Jul 20, 2014 | 05:26 PM
stecozz's Avatar
stecozz
Default Jerking around problem
At around 2000rpm in 3rd or 4th gear the the car jerks back as if the fuels being cut, the afr jumps round to the red zone 15.5 to 17!
Ive a new fuel regulator and i tried a couple of 3bar map sensors and its still the same.
Any ideas as im scared to drive it now so not to do any damage ?
Old Jul 20, 2014 | 05:31 PM
stecozz's Avatar
stecozz
Its a big turbo running greys and doesnt run closed loop.
Old Jul 20, 2014 | 06:06 PM
dave cos4x4's Avatar
dave cos4x4
it may be the throttle position then Ste, its not cutting the fuel off when it should, fuel still going in and the car is trying to go.
Old Jul 20, 2014 | 06:12 PM
stecozz's Avatar
stecozz
Ive set the tps a few times Dave but its still the same, its as if the fuel is cutting off as the afr goes very lean.
Replaced the tps aswell.
Old Jul 21, 2014 | 09:18 AM
Jay,'s Avatar
Jay,
Sponsor
Have you pressure tested the system for any leaks ?
Old Jul 21, 2014 | 09:27 AM
stecozz's Avatar
stecozz
Gonna check it tonight but i pretty sure its ok, strange that it only happens around 2k off boost.
Old Jul 21, 2014 | 11:10 AM
jessie_rs's Avatar
jessie_rs
Mine has also developed this problem I am running t34, 83lbs and closed loop. I put it down to tps problem. Its like a small power cut for 1-2 seconds then straight back on.
Old Jul 21, 2014 | 07:02 PM
stecozz's Avatar
stecozz
Just found a big air leak by the number 4 cylinder on the inlet.
Finally found the problem well fingers crossed.
Old Jul 21, 2014 | 07:07 PM
Jay,'s Avatar
Jay,
Sponsor
Thought it was a leak lol
Old Jul 21, 2014 | 07:10 PM
stecozz's Avatar
stecozz
Explains the high idle too
Old Jul 21, 2014 | 07:19 PM
dave cos4x4
you never mentioned the high idle lol.
Old Jul 21, 2014 | 07:24 PM
Jay,'s Avatar
Jay,
Sponsor
No you didnt fuckin naughty boy
Old Jul 21, 2014 | 07:43 PM
dave cos4x4
lol
Old Jul 21, 2014 | 08:12 PM
stecozz's Avatar
stecozz
Soz wasnt that high around 1050rpm on a good day
Always thought it was high even though i was told it was ok
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
