Caliper Seal
Hi,
My rear offside caliper has sprung a leak, given this only happened Monday evening I have not had the wheel off yet to have a proper look, but from what I have seen so far it looks like the caliper.
I only fitted it just over 3 years ago, therefore I would like to change the seal myself if possible, however, I know these are a pain with regards to the handbrake mechanism spring.
Therefore I am looking for advice from others who have done the same, so far I understand I will need a G-clamp and a pair of circlip pliers, is it feasible to do this with just these tools? (I don't have the latter, so will have to borrow)
Thanks.
Martin
Thanks.
Martin
Thanks Jon,
I haven't had a chance to look yet, but at a glance due to the position of the fluid on the caliper I thought the source may be the handbrake mechanism.
If it's the piston seal then it's a relief!
Martin
Martin
As suspected, it's the handbrake seal
I have enquired with a couple of factors and they are readily available, the thing is I know they will be silver, opposed to gold (as replaced as a pair) and given mine is new, I would like to replace the seal, if possible.
Ridgey, this is where the calipers were from, incidentally.
I have found a kit for one caliper, usually these are sold as a pair, so not too expensive.
My concern is the absence of the special tool (12-007 to be precise) used to compress the spring, I am aware you can improvise and use a socket in it's place for example.
I have a G-clamp, therefore I just need a pair of circlip pliers, right?
Martin
Martin
Got a seal kit and a replacement caliper, spent all weekend on the latter and had to get a new brake hose, due to other one leaking at the union.
Plan is to rebuild my old one, just need to get myself a pair of circlip pliers.
A couple of questions:
The union looks good on the braided hose, the copper washer can not be removed as it's too small for the thread, is this normal? I had planned to anneal it, but judging by the amount it was leaking, I don't think this will help, so I guess the union is just worn.
With the rubber hose the union is slightly longer and as a result I have a little thread exposed, is this right?
Martin
Martin
