Escort Cosworth oil pressure sender.
Hi,a friend trying to find a new oil pressure sender for a 93 Escort Cosworth. It has VDO stamp and a Ford part number on it.Ford dealer could not find it in the system. Can he use any type of VDO oil pressure sender with 0-5 bar? Many types of them on Ebay.uk etc.
http://shop.motorsport-developments....itch-172-p.asp
http://shop.grahamgoode.com/oil-pres...68-69433-p.asp
http://shop.grahamgoode.com/ggr-oil-...35-70895-p.asp
Tee piece if needed.
http://www.etbinstruments.com/Sensors_ancillaries.htm
This is the one you want. 3rd from the bottom in the VDO section.
Escortdriver1
Jul 31, 2015 02:36 PM
