215/40/17 tyres
Old Jul 9, 2014 | 10:44 AM
Stokesy's Avatar
Stokesy
Default 215/40/17 tyres
Will they catch the arches on 17x7.5 ET37 alloys with koni struts lowered by 25mm?
Old Jul 9, 2014 | 09:49 PM
cossynut2's Avatar
cossynut2
10 Year Member
Question
2WD
What car are you talking about? I have a 1990 2wd Sapphire with Koni shocks and Eibach lowered springs on the front and Bilstein shocks with the same springs on the back, 35mm lower than standard and even though all the arches have been rolled when I tried to fit 215/40/17s they touched the arches. Maybe you will be able to fit them as you are only 25mm lower but I have my doubts. I run 205/40 /17s and there is no problem with them clearing ok . Before you buy the tyres make sure they will clear your arches.
Cheers Richard.
Old Jul 9, 2014 | 10:35 PM
Stokesy's Avatar
Stokesy
Car is a 4wd sapphire
Old Jul 10, 2014 | 05:25 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Will fit perfect
Old Jul 10, 2014 | 06:19 AM
cossynut2's Avatar
cossynut2
10 Year Member
Originally Posted by MARCOSWORTH
Will fit perfect
There must be a difference between the 2wd and 4wd suspension set up to allow you to be able to fit the 215/40/17s without any clearance problems ?
Old Jul 10, 2014 | 11:28 AM
DAN400's Avatar
DAN400
fit perfect on my 2wd
Old Jul 10, 2014 | 12:07 PM
cossynut2's Avatar
cossynut2
10 Year Member
Question
I am suprised they do , have you lowered it and rolled the arches? When I tried fitting them on my 2wd they hit the arches even though I have had them rolled.
Old Jul 10, 2014 | 12:12 PM
Marc sierra's Avatar
Marc sierra
Maybe a wrong ET value? In my experience 215/40 17 should be fine, also on a lowered car.
Old Jul 10, 2014 | 04:29 PM
cossynut2's Avatar
cossynut2
10 Year Member
Maybe because they were track day semi-slicks?
Old Jul 10, 2014 | 04:53 PM
DAN400's Avatar
DAN400
fronts are rolled and lowered yes , back arches are std
Old Jul 10, 2014 | 07:34 PM
Paul_RS's Avatar
Paul_RS
215/40/r17 don't rub on mine with totally standard arches.
Old Aug 23, 2015 | 06:50 PM
chowfornow's Avatar
chowfornow
What offset are you running? And what suspension set up?
I've just picked up some mo5 8x17 et35
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
