SportKa Engine Transplants
Old Jul 9, 2014 | 12:04 AM
poultergeist's Avatar
poultergeist
Default SportKa Engine Transplants
What conversions are fairly simple to do into a SportKa,ie pretty much drop straight in? Was thinking good old Puma? But what about 2 litre Blacktops etc?
Old Oct 5, 2014 | 12:34 AM
corkfordfan's Avatar
corkfordfan
The puma engine will bolt to your gearbox, you just have to make an engine mount for the timing belt side, Id prefer to modify the rocam, having a sportka myself the engine has bags of potential, a one litre version was available in mexico with a supercharger put out over 90 brake. If you wanted 1.8 or 2.0 zetec you need pre 03 1.3ka gearbox and modify the slam panel a little
Old Oct 8, 2014 | 07:12 PM
poultergeist
What's a rocam? Isn't the Puma lump a lot more involved than a 1.8/2.0 Zetec?
Old Oct 8, 2014 | 07:22 PM
st220kyle's Avatar
st220kyle
Rocam, the engine in a sportka although badged a a duratec
Old Oct 8, 2014 | 10:05 PM
corkfordfan
No you need to change the engine the loom and ecu and ignition key chip, make one engine mounting for the timingbelt side either way, but if you go 1.8or 2.0 youll have to change your gearbox too
the 1.7 is a better choice as its easier and lighter, sportkas are nose heavy enough as they are
Old Oct 9, 2014 | 06:38 AM
poultergeist
Yeah I suspected the Puma lump would be a bit lighter,but isn't there less tuning potential? Im sure I heard the 1.8/2.0 could mate up to the Sport gearbox,is that incorrect then?
Old Oct 9, 2014 | 06:46 PM
corkfordfan
Everything can be tuned if your gonna spend enough on it, theres trottle body kits etc if bringing one to racing puma spec isnt enough for you, the bigger zetecs would mate to your gearbox but youd have nowhere to put your starter motor.
hopper350
Sep 4, 2015 12:53 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
