Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
ESP warning light stuck on - 2006 Fiesta ST
Old Jul 7, 2014 | 02:32 PM
merlin7835's Avatar
merlin7835
Exclamation ESP warning light stuck on - 2006 Fiesta ST
Hi all,
I've had the ESP light on my 2006 ST stuck on & I can't turn it off with the button on the dash above the stereo.
I've been told by a mechanic it's the ABS and to get rid of it I need the pump replacing, which I don't believe.
I called Ford and they said it's likely to be a fault with the system / the ESP sensor.
Anyone know what this is? Obviously the ESP doesn't kick in if I wheel-spin, but I know the ABS works fine.
Obviously don't want to fork out for a new pump and if would be good to know if there is an easy fix!
Thanks in advance
Old Jul 7, 2014 | 04:01 PM
oldford's Avatar
oldford
What are the fault codes, if possible complete with number?
Old Jul 7, 2014 | 05:23 PM
merlin7835's Avatar
merlin7835
Hi Oldford,
I've been given given "C1288 Brake pressure sensor circuit failure main/primary input"
Even though the ABS works fine and it's the ESP that is stuck off.
I've been told to check the steering wheel angle (reset) know if this is easily done?
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Bailes1992
Sep 3, 2015 02:17 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
