03 Focus missfire 1 and 4
Old Jul 3, 2014 | 07:17 PM
packman's Avatar
packman
Default 03 Focus missfire 1 and 4
Hey not the fastest thing in the world but a good hack ...
2003 1.6 petrol , went round a corner and then it started miss firing
Dragged it back and its firing on 2 & 3 but not 1 and 4 , tried a coil pack and crank sensor but nothing ....
Tried all the fuses there all ok so its not switching on 1 and 4
Anyone came across this before ?
Old Jul 3, 2014 | 07:45 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
had similar, coil pack was fooked,
replaced with working 1, no more missing
Old Jul 3, 2014 | 07:46 PM
Have you tried spark plugs and leads.
Old Jul 3, 2014 | 07:48 PM
RichieST's Avatar
RichieST
First thing I would do is find out if you've lost spark or fuel. Any DTC's?
Old Jul 3, 2014 | 07:54 PM
studabear's Avatar
studabear
Duff coil pack. or wiring issue or ecu.
Old Jul 3, 2014 | 08:54 PM
packman's Avatar
packman
tried a new coil pack and crank sensor still the same ...
plugged it in and it said coil pack .....
2 & 3 is working 1 & 4 is not
Old Jul 3, 2014 | 09:15 PM
mk2grp1's Avatar
mk2grp1
you tried a new coil . brand new ?
Old Jul 3, 2014 | 09:32 PM
studabear's Avatar
studabear
if you have any test leads or wiring see if you can switch the 2 outer wires on the coil pack plug, then swap leeds 1-4 with 2-3 and see if you get spark on 1-4 and none on 2-3
Old Jul 3, 2014 | 09:39 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
stop throwing bits at the car and diagnose it propperly!!
coilpack witing has 3 wires, centre is feed/gnd
both outers are pulsed signal/triggers
1/4 2/3
while cranking using a test light, see if signal is pulsing on both outer terminals with connector unplugged.
you should get the same result on both outer connectors.
if not then do continuity check on the wiring to PCM, if thats ok then check the pulses at ECU by back probing.
you will find the ECU drivers have failed due to leaving a missfiring coilpack on too long and its fucked it.
Sean.
Old Jul 6, 2014 | 09:54 AM
B19 JUB's Avatar
B19 JUB
1/4 2/3
Sean.
totally what he said.if the three wires from ecu to coil pack are ok then the coil driver in the ecu is fudged.if it is and you replace ecu make sure you put a brand new coil pack on it at same time otherwise it will do the same thing again
Old Jul 6, 2014 | 06:33 PM
big.p's Avatar
big.p
Do as stated above easiest way is use a noid lamp into the coil pack multi plug and crank the car if u haven't got a noid use a cap less sidelight bulb with wires bent back
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
