mondeo tdci expansion valve location ???
we have a 2006 mondeo tdci and need to locate the air con expansion valve ( fixed orifice tube )
having problems with over pressuring on high and low sides any help appreciated
thanks paul
thanks paul
if you are lucky it will be the one behind the drivers side headlight
if you are unlucky it will be the one underneath the drivers side wheel arch liner
i'll get a pic for you in a second
It's the in line expansion valve that has the filter incorporated with it ! Ford don't sell it separate (it comes with a pipe
Just never done one before and didn't know exactly where it is.
Nope no idea where that goes
The filter is under the wheel arch liner as well and the pipe runs from the condensor to the connector under the wing
Not sure where that part is located
Well to help anyone out in the future
it was in the pipe behind the osf strut tower,just above the ECU So Chris was right as its heading to the evaporator cheers bud
That's the new one in my hand and you can just see the orange tip of the old one inside the pipe,
Changed the expansion pipe and it still over pressured
turned out to be a faulty fan control module
so the air con had a service to boot
so the air con had a service to boot Last edited by paulmex; Jul 11, 2014 at 08:45 PM.
Here you go mate
http://www.auto-repair-help.com/auto...e_receiver.php
Explains it better than my college memory explanation
