S2 fuel lines
Lines under the car mate.... It's just a road car it's a 2 door estate that was carb now turbo got everything engine bay wise it's just the stuff under the car.... Got tank and pump allready
8mm microbore copper pipe 4 meters. EBay 12 quid. Small pipe bender for 4 6 and 8 mm 9 quid eBay. Brake pipe flaring kit 12 quid eBay. You tube for how to do the two different types of flaring. Local motor factors for 8mm rubber fuel hose for tank connections and engine bay. Job done all for under 40 quid
You can use the original ones mate, well the one any way, on turbo models there the same size on carb the return is usually smaller, In the past when turboing a carb car I just change the return for a larger diameter feed pipe off another car.
Ginger
Ginger
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
Dubs44
Sep 19, 2015 06:31 AM
