Poss drive shaft clicking after cv gater replacement
Hi all hope someone can help,
I recently had my focus st 225 OS drive shaft gator replaced and since then I've noticed a clicking/clonking noise especially when going between 1st and reverse.
I seem to remember some sort of ford recall and remember someone put a ford data sheet on here about this issue, can anyone shed some more light on this please.
Cheers for reply, it was the inner joint that split but I'm convinced it's coming from the outer joint!!! The garage did change this gator too as they managed to split it when putting it back together!!!!!
Studabear this is all the time mate! It clonks when I go from 1st to reverse or visa versa and I get a slite ticking sound (normally two clicks) when I pull away in slow traffic and again I get the same two when i stop!! Never done this before they replaced my cv !!!!!!
Adam Graham
Sep 6, 2015 06:04 AM
