Pink relay
Old Jun 30, 2014 | 04:31 PM
Marc D's Avatar
Marc D
Default Pink relay
Hi, my pink relay melted today and I've replaced it with a brand new genuine one but the fuel pump doesn't prime however it does start and run and the fuel pump works when the engines running. Is there an issue with the new relay? Fuel pump is about 2 years old and is a genuine Bosch
Thanks
Old Jun 30, 2014 | 11:35 PM
blackbeautyzetec's Avatar
blackbeautyzetec
You need to find out why it has melted. I wouldnt be putting a new one in if that melts too.
Check the wires to the fuel pump have a clean connection. Check the wires to the replay plug are good
Old Jul 1, 2014 | 08:13 PM
martysmartie's Avatar
martysmartie
I wonder if you have the correct one for your car, what do you define as the genuine one?It sounds like you have a conventional relay, the correct one has a timer so that the pump will prime.
Martin
Old Jul 2, 2014 | 05:32 PM
Red_bull's Avatar
Red_bull
If it has the right pressure already it does not prime. Isn't that your "problem"?
Old Jul 2, 2014 | 11:15 PM
martysmartie
I disagree with this, the pump will prime all the time, irrespective of pressure. There is no way it can know the pressure!
Martin
Old Jul 3, 2014 | 08:24 AM
haz87's Avatar
haz87
Martin
^^^ agreed
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
tib2220
Sep 14, 2015 12:33 PM
