Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk 3 fiesta rear disk conversion can it be done
Old Jun 27, 2014 | 04:34 PM
joeb's Avatar
joeb
Default Mk 3 fiesta rear disk conversion can it be done
Rite I've got a mk3 Feista and want to convert rear brakes to disk can this be done if so how ???
Old Jun 27, 2014 | 04:44 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I believe people use a Focus set up for rear discs, not sure on the details though.
Old Jun 27, 2014 | 04:58 PM
joeb's Avatar
joeb
Cheers man ill have a look into it
Old Jun 27, 2014 | 08:51 PM
shalon's Avatar
shalon
mk5 axle with focus stubaxles and carriers calipers etc
Old Jun 29, 2014 | 05:24 AM
joeb's Avatar
joeb
Cheers pal
Old Jun 29, 2014 | 11:39 AM
XR2's Avatar
XR2
MK5 means Fiesta 99-02.
MK6 (02-08) won't fit.
Old Jun 29, 2014 | 12:37 PM
joeb's Avatar
joeb
Mk5 fiesta is still drumbs on back really wanna run disks
Old Jun 29, 2014 | 01:07 PM
XR2's Avatar
XR2
as above. 99 Fiesta rear axle with Focus MK1 parts.
Old Jun 29, 2014 | 04:15 PM
joeb's Avatar
joeb
Ohhhh I see that makes sense now
Old Jun 29, 2014 | 07:41 PM
Oranoco's Avatar
Oranoco
You will also need to add in some bias valves to take away most of the braking effort or the first time you stamp on the middle peddle it will be like yanking the handbrake.
The drums are perfectly up to the job of stopping a Mk3 Fiesta so I would leave well alone. Even my mates 400bhp Zetec Turbo is still using the drum setup on the back
Old Jun 29, 2014 | 07:49 PM
dakar's Avatar
dakar
Can you not fit em to a mk3 beam?
Old Jun 29, 2014 | 09:02 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
As above, drums are more than capable in a light car like a Fiesta. If you are adamant about upgrading then you could possibly look at the bigger drums that came on later Pumas, I'd imagine they'd fit without much hassle. Also be worth getting hold of a Mondeo master cylinder.
mint_s2
Sep 2, 2015 08:58 AM
atm
Sep 1, 2015 04:56 PM
RsS2daz
Aug 14, 2015 05:26 AM
Bosch
Aug 4, 2015 05:14 PM
