Need Help for 1989 Sierra Coupe
Old Jun 25, 2014 | 10:42 AM
partus's Avatar
partus
Default Need Help for 1989 Sierra Coupe
Hello Everybody,
I purchased Ford Sierra 1989 1,6 Coupe
I wanna change engine.
I wanna use this one.
I want to learn that, can i use use this engine with cars original manifold and injector system. Or if i want to use weber carburetor what should i do.
Best Regards
Old Jun 30, 2014 | 06:41 AM
partus's Avatar
partus
Is there anyone that can help?
Its too urgent for me.
Best Regards for everybody
Old Jun 30, 2014 | 12:14 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
Hi retro ford sell engine mounts or you can buy a kit you weld yourself
the inlet manifold can be replaced for different carbs twin 40 webers or a twin dgav
sump is most likely for a front wheel drive , I think a 1.8 cvh sump fits for rear drive,
the ignition , (sparks for engine) a ford 1.3 hcs edis unit will work, if you need low cost,
or other management systems are available / emerald/ megasquirt/ megajolt/ weber alpha/ there are many more
exhaust manifold can be brought for a rear drive, or you can cut and modify yours,
or possibly use complete, easy to work out when engine is in
coil pack may need relocating, it is possible to run the engine as it is, if you can fit wiring loom and ecu from a /focus / esocrt /or mondeo
there is perhaps more help if you use "search" on old topics on here,
and google search will find a website "zetecinside" flywheel from 1.8 zetec engine or a 1.6 cvh efi (the one that uses a coil pack) 1.8cvh engine may have coil pack if so you can, the sparking system and trigger wheel, plus the sump as mentioned earlier
great looking shell, keep us posted with pics , good luck,
Old Jul 2, 2014 | 09:59 AM
partus's Avatar
partus
Thanks For interest and help.
Let me check
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
