Wiring - Green signal wire
Old Jun 24, 2014 | 09:07 PM
BRAMMER's Avatar
BRAMMER
Default Wiring - Green signal wire
Does this seem right,
Green RPM signal wire on the dash clocks long plug
From these instructions will these be fine to fit to join the yellow wire here rather splice into the ecu plug wiring?
Old Jun 26, 2014 | 09:34 AM
BRAMMER's Avatar
BRAMMER
Anyone know?
Old Jun 26, 2014 | 12:54 PM
killa_paul's Avatar
killa_paul
Hi mate im pretty sure you will be fine to do that, this is where i took the feed for my engine monitor from. if my memory serves me it is connected to the ecu loom via the plug behind the dash connector, so you can take it from there no prob
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
