Pump not priming :(
Old Jun 21, 2014 | 03:20 PM
Scott_Rst's Avatar
Scott_Rst
Default Pump not priming :(
Hey guys,
Escos had been sitting for nearly 2 years in garage without being started, so new fuel, oils water level checked etc etc, but wen tried to start just winding, initially thought spark, but plenty of spark to all cylinders, then noticed fuel pump wasn't coming on, run live to pump it works, so I know pump is ok, also even tho I put 25L of fresh fuel in the fuel light and gauge are still saying there's nothing!!!??
So I guess I'm asking is there any common relay or anything that could be gone etc??
Cheers!
Old Jun 21, 2014 | 05:39 PM
james kiely's Avatar
james kiely
have you an alarm/immobiliser problem maybe ?
Old Jun 21, 2014 | 05:51 PM
martysmartie's Avatar
martysmartie
Most likely the relay has stuck, a little tap or 'flick' on it should resolve it.
Martin
Old Jun 22, 2014 | 10:13 AM
Scott_Rst's Avatar
Scott_Rst
Was thinking it could be immobiliser but it all seems to be working fine,
Any idea which relay it would be and where?
Old Jun 22, 2014 | 10:55 AM
tones's Avatar
tones
Pm sent
Old Jun 23, 2014 | 12:29 PM
martysmartie
I doubt it's an immobiliser issue, given you have ignition etc.
The relay is yellow I should think and it's probably behind the dash.
Martin
Old Jun 25, 2014 | 12:26 PM
luke19790_3's Avatar
luke19790_3
Maybe a poor earth connection
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
