ideas please, ongoing problem
Old Jun 17, 2014 | 09:13 PM
stewarthannah's Avatar
stewarthannah
Default ideas please, ongoing problem
the car went through a phase of idling erratically and eventually chugged itself out when left sat running, then when driving in heavy stop start traffic, after a period of time the engine would stall when braking and coming to a stop, the idle and timing was altered and it seemed all rosy until today, and again through heavy stop start traffic after a period of time if i didnt fight to keep the revs up the car would cut out and stall and so was a real struggle to get it home, any experience or advice would be useful thanks!
Old Jun 17, 2014 | 09:18 PM
De4n0's Avatar
De4n0
As is the answer to most question with similar problems your best bet would be to check your idle control valve, may need a clean or replacing, what car/engine have you got?
Old Jun 17, 2014 | 09:25 PM
stewarthannah
standard bar a pace intercooler, hybrid turbo and a remap. hmm, altered the idle which seemed to solve the problem but maybe def worth another look at it, seems to mainly be a problem after long periods of stop start slow driving
Old Jun 17, 2014 | 09:30 PM
De4n0's Avatar
De4n0
What engine mate?
Old Jun 17, 2014 | 09:32 PM
studabear's Avatar
studabear
Sounds like it needs a set up.
Old Jun 17, 2014 | 09:41 PM
stewarthannah
original cvh mate, bar the listed mods. hmm maybe that be required to iron out the probs. has been spot on last couple of months
Old Jun 18, 2014 | 04:21 PM
RSmark84's Avatar
RSmark84
As above get it set up, mine did the same as what you described. What engine are you running in your car. Mine is MFi.
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
fuzzy
Sep 4, 2015 10:11 PM
ST-170
Sep 4, 2015 11:02 AM
