2wd cams into 4wd head
Has a large member
Im swapping all the bits off my old 2wd head onto a fresh 4x4 one.
Other than 4x4 cam bearings and seals is there anything else i need to do in order to make them fit?
i know 4x4 setups run with a spacer but is that still relivant when using 2wd cams?
Thanks
Thanks
Has a large member
Yeh I've discovered it can't be done. Know of ppl who run them but the belt doesn't sit bang in the middle of the pulley, not a risk I'm willing to take!
Got an old pair of 4x4 cams stored away that will just need the lobes scotching so will use them!
rog
Sep 4, 2015 07:24 AM
