Help with Coil Spring ! Thanks
Old Jun 15, 2014 | 10:37 AM
akronos's Avatar
akronos
Default Help with Coil Spring ! Thanks
Hello i'm Mark from Italy, in my country it's very hard to find aftermarket parts for my car (escort s2). I need to change Coil Spring and i found two model of springs.
FIRST : http://www.maxxtune.de/product_info....-su25008-.html
SECOND: http://www.fk-shop.de/en/Suspension-...c75ec92b62e850
I need help!
Old Jun 15, 2014 | 01:34 PM
studabear's Avatar
studabear
What do you need help with?
Old Jun 15, 2014 | 04:15 PM
akronos's Avatar
akronos
i need to know if i buy fk automotive 75/50 mm loweing spring: i must cut the suspension stem ?
Old Jun 15, 2014 | 08:27 PM
mat_rss2's Avatar
mat_rss2
Aftermarket dampers would advised mark, though I would say 50 to 75mm on rst's is not very practical and neither the best for handling. If you went for the 40mm option you should be ok on your standard dampers but notice a sharpness in the handling department
Old Jun 23, 2014 | 06:58 PM
makaveli96's Avatar
makaveli96
I wouldn't go past a 40mm drop 30-35mm will be most suited.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
beller
Sep 21, 2015 04:13 AM
