Classic Ford Model A V6 Conversion
Old Jun 13, 2014 | 09:05 PM
MJ_RST's Avatar
MJ_RST
Default Classic Ford Model A V6 Conversion
Here's some pictures of the current customers project build we have in at the moment:
Arriving on Monday
The task - Strip the Dorchester Limo and put all the running gear and wiring loom across to the Model A
2.9 EFi V6
Dash removed, wiring loom and the dreaded PATS included
She's in, with custom engine mount brackets
Custom steering column
Auto shifter, pedal box, steering column in place. Wiring loom being routed. Custom brackets required to hide the ecu and fuse boxes behind the dash.
More progress updates on our facebook page as we go along
Old Jun 13, 2014 | 10:16 PM
auldy's Avatar
auldy
Running the same engine in my mk1 Tina but with a manual box, great noise from it!
Look forward to the updates
Cheers,auld
Old Jun 14, 2014 | 04:28 AM
Cool project. I would love a hot rod.
What does your cortina go like with the V6 in.
Old Jun 14, 2014 | 10:17 AM
MJ_RST's Avatar
MJ_RST
Cheers,auld
Superb, are you running with the EFi PATS or did you go an alternate route?
Mk1Kieran
Shows & Track Days
Aug 31, 2015 08:14 AM
Shows & Track Days
Aug 26, 2015 05:11 AM
borboyous
Aug 22, 2015 11:17 AM
Shows & Track Days
Aug 17, 2015 08:56 AM
Aug 8, 2015 07:12 AM
