Ford Puma Discuss the Ford Puma here!
Abs problems.
Old Jun 12, 2014 | 05:15 PM
lee2cossies's Avatar
lee2cossies
Default Abs problems.
Have a problem with my 98 puma. It started with the abs light coming on, with the light on the brakes work as before so thought possibly a sensor needs changing, but now when the light occasionally goes out, the brakes are really bad! As if the pedal is traveling further and like the abs is switching on/off! Any ideas?
Old Jun 12, 2014 | 05:45 PM
oldford's Avatar
oldford
I would start by having the fault codes read from the ABS system.
Old Jun 13, 2014 | 12:05 PM
Ive got a fault with the abs on my puma since I put rear axle spacers in. The light would come on then go off then the brake pedal would buzz on my foot when pressed.
I think the sensors on mine need reseating.
Does you abs light go out.
Old Jun 13, 2014 | 12:32 PM
lee2cossies
When the light goes out I have the buzzing fault and poor brakes! Which is what's confusing! Nothing has been touched on the car it just appeared one day.
Does a normal fault code reader check the abs too then?
Old Jun 13, 2014 | 06:27 PM
Check your sensor faces and the pick up rings. Mine was doing a similar thing and I think its cause the space between the abs sensor and the rear pick up rings are too big.
Old Jun 14, 2014 | 04:50 PM
lee2cossies
Thanks Glenn, had a look today and looks as if it's had a new sensor in the past and hasn't been fitted properly so has rubbed the wheel on full lock and got squashed. It doesn't look as tho the wires are damaged but the sheath is so going to replace it with new hopefully that will sort it.
Old Jun 14, 2014 | 05:30 PM
Fingers crossed. I had a look at my puma today cause my abs light has been on for a few weeks. I wheel span the car into the workshop and the light went off lol.
Stuck the ford ids tester on and ive got faults on the rear sensors. Im wondering if the sensors arnt fitted correctly since I fitted the rear axle spacers.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
