AB07 Inlet Cam with tappets, less than 100 miles done
So I brought this cam because my pistons didnt have valve cut outs, fitted the cam and drove the car locally to sort a few issues then decided to pull the engine apart so decided to get the valve cut outs and fit a more lairy cam.
The cam has done less than 100 miles and cost £232 direct from Kent Cams, the tappets are around £80 for a set to which you will be receiving half the set ie inlet side. All tappets are numbered for which lobe/ valve they came from
Looking for £180 plus postage
Pictures to follow tonight
grishenko45
Sep 9, 2015 12:58 PM
rog
Sep 4, 2015 07:24 AM
