st focus 2.5 into mk2
Old Jun 12, 2014 | 08:19 AM
wally-rs's Avatar
wally-rs
Default st focus 2.5 into mk2
Hi guys
Is there any info on installing this engine into a mk2 escort as i plan to do this conversion shortly,ive done some research but cant seem to find any threads. i want to use the st engine rather than a t5 volvo
Old Jun 12, 2014 | 08:26 AM
chris cdti's Avatar
chris cdti
i think you should read up on the st engines block weakness. You may find the 2.3 engine from an 850R or V70R will be stronger.
Old Jun 12, 2014 | 09:12 AM
wally-rs's Avatar
wally-rs
Yes ive read that, only plan on going to 300bhp ish ive got a early t5 angine no vvt ,on dizzy but want a more modern engine also does anyone know of someone that could possible delete all signals that the ecu will look for apart from what the engine needs to run
Thanks for your replie.
Old Jun 12, 2014 | 09:22 AM
luke19790_3's Avatar
luke19790_3
Have a look on here someone is doing that conversion
Old Jun 12, 2014 | 09:28 AM
luke19790_3
It's not a mk2 but should be the same
https://passionford.com/forum/restor...s-of-pics.html
Old Jun 12, 2014 | 07:55 PM
wally-rs's Avatar
wally-rs
Yes that 100e a great build, iam on a budget so ive had the st sump cut and added extra oil capacity to n/s of sump also running a 6 speed diesel bmw gearbox which is good for 400lb/ft of torque ,gearbox cost Ł100.
Old Jun 12, 2014 | 08:07 PM
studabear's Avatar
studabear
Will be great to follow your project, stand alone engine management might be a lot easier than trying to incorporate the ST wiring?
Old Jun 14, 2014 | 04:34 AM
So will you be cutting out the bulk head for the engine to fit in the bay.
Old Jun 14, 2014 | 08:16 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
ST blocks have been known to crack even at standard tune, but some have run well over 300bhp without issue. Pot luck.
Old Jun 14, 2014 | 08:18 PM
wally-rs's Avatar
wally-rs
Yes havent had the sump back yet but measured and looks like about 50mm
Old Jun 20, 2014 | 06:38 AM
wally-rs's Avatar
wally-rs
Hi guys
Anyone know what ecu's will run the st 5cyl engine and any wire diagrams for that ecu
Old Jun 20, 2014 | 08:35 AM
surrey_100e's Avatar
surrey_100e
I'm using vipec v88, it allows up to 12 cylinders, where as the v44 only 4.
Just search the internet, for the wiring, you will find it.
I still have the original ecu if it's any help...
Got any photos?
Old Jun 20, 2014 | 09:16 AM
wally-rs's Avatar
wally-rs
Got any photos?
Thanks, i have the st ecu still waiting for my sump will take a few pics of it when its back.
TPM961
Jan 15, 2018 10:50 AM
Brickhouse
Sep 20, 2015 11:47 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
